Pass/Fail counter question. [Help]
Hello! Can someone please help me figure out how to count the # of Passed & Failed Samples below? Each test samples has to go through series of test procedure (Test - 1, 2, & 3) and I need to determine if the sample has passed or failed base on the test procedures..
Thanks!
20245i270262C424C53156
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
Message 1 of 33
(7,130 Views)
Hey there
What are the conditions for the pass and fail and do you have a VI with a completed block diagram you could attach to your reply?
Regards
Ben
Message 2 of 33
(7,113 Views)
Actually I have no control for conditions, I'm just pulling the data using DB Connectivity Toolkit... The attached information is diced out from the table I've gathered from our database.
Thanks!
______________
KowdTek
LabVIEW 2009
Message 3 of 33
(7,102 Views)
The OpenG Search Array will give you the indices of each, the Array Size returns a count.
20259i7BE1EC569A35F1CF
Jim
Message 4 of 33
(7,093 Views)
Accepted by topic author KowdTek
Jim's solution will give the number of Pass events and the number of Fail events.  I'm thinking that the OP wants a number of samples that passed or failed, not a pass/fail count.  Look at the two indicators in his front panel picture.  A sample passes only if it passes all three tests, otherwise it fails.  I have modified Jim's code to return the number of samples that passed and failed, rather than a simple pass/fail count.
20261iD3563BC1DFAD53BD
- tbob
Inventor of the WORM Global
Message 5 of 33
(7,086 Views)
Thanks for those who replied... The last example works great but since my application will be use to a several machines I will need to define the number of test procedure (TProcedure) on each one.
Thank you very much guys!!!
______________
KowdTek
LabVIEW 2009
Message 6 of 33
(7,080 Views)
Create a numeric control and call it Num Tests or something like that.  On the block diagram, delete the numeric constants with 3 in them, and wire the control to those points.  There are only two instances and they are the bottom input to the Quotient & Remainder functions.  Then just enter how many tests there are in the numeric control,
- tbob
Message 7 of 33
(7,064 Views)
That's the plan... Smiley Wink
Thank you...
______________
KowdTek
LabVIEW 2009
Message 8 of 33
(7,061 Views)
How do you tell the difference betweeen:
  • One sample failing all three tests
  • Three different samples failing one test each?
Message 9 of 33
(7,053 Views)
If we can assume that the test are arranged in a regular pattern, three tests in a row for each sample, here's what I would do.
(Also assuming that the capitalization is the same for all "Pass" and assuming anything that is not a pass is a fail. ;))
Message 10 of 33
(7,045 Views)
