Cannot open vi dynamically when it contains tcp controls
The idea is that I have a framework for collecting data. The thing is that I don't know beforehand how the data is collected. Therefore a vi is opened dynamically to retreive this data.
When I use udp controls in this vi to retreive data over a network, everything works fine. However, when I use tcp controls I get error 1003: "The VI is not executable". The error appears in the "Open VI Reference" control.
I don't see why this should be a problem.
Lars Melander
Uppsala Database Laboratory, Uppsala University
(2,638 Views)
Can you confirm the VI is not broken?
For error 1003 there must be either a missing dependency, or the VI itself is not executable.
If you could post your VIs that would be helpful.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(2,632 Views)
"sandvik.vi" is the vi I want to open. "callout_vi_check.vi" is one vi I use to open a vi.
I forgot to mention, opening "callout_vi_check.vi" and running it works just fine. It's when I compile it to a dll and call the function that I get the error.
Lars Melander
(2,622 Views)
A little more detail might be needed to understand this.
Exactly what are you compiling into a dll?
I can see that callout_vi_check.vi has the "Default path" function, so I presume you keep your VIs in the LabVIEW installation folder?
If you are building a dll, what method are you using to call the dll?
(2,619 Views)
Accepted by LarsM
"Default path" in this case returns the folder where my program is.
Anyway, I've found a solution. The problem is somewhere inside the "TCP Listen.vi" subvi. I switched it for the "TCP Create Listener" and "TCP Wait On Listener" controls and now everything works fine.
Lars Melander
(2,610 Views)
