 wildcatherder
			wildcatherder
			07-12-2010 05:27 PM
I have three charts which use a common time scale. The attached JPG shows how I use an initial structure to set YScale minimum and maximums, as well as XScale Maximums. When I run the VI, the YScale changes take effect immediately, I can see them on the front panel. Unfortunately, the XScale maximum does not change.
If I stop the VI and restart it, the XScale maximum is now set to the desired value.
Why does the XScale take two passes? Is there a way to update the XScale on start?
Solved! Go to Solution.
07-12-2010 06:01 PM
I managed to solve my own problem:
The XScale value was being set by Calculated Total Run Time. However, that value was in the second sequence frame and thus, was not available to change the XScale maximum. I added another frame at the beginning which does nothing but take the entered time values and calculate various conversions and sums.
