Scale factors for individual inputs
I am new to LabView. I am simultaneously acquiring 4 channels of acceleration time histories using DAQ assistant. I want to rescale each channel with a different factor (associated with different sensitivity of my accelerometers), before presenting all the channels on the same graph. All I managed so far is to rescale all channels with the same factor. Can anybody help? Many thanks.
(3,620 Views)
do you have code for us to see. It would make it much easier to help.
Tim
GHSP
(3,603 Views)
Separate the channels using unbundle or index array, scale each one, then combine again using bundle or build array.  Then send to the graph.
- tbob
Inventor of the WORM Global
(3,596 Views)
Without at least a .png of your block diagram I'll take a guess. You need to use the split signals function.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,587 Views)
Please attach an example so we can see your datatypes.
If it's just a 2D array, you can use a FOR loop and multiply with a 1D array of four different values.
(3,582 Views)
Or in the DAQ Assistant, apply a different scale to each signal.
(3,578 Views)
