Cannot set string to be empty
Hello all
Newbie question coming up.
I am implementing a state machine to control the initial part of a test sequence. I need to scan a barcode and then look up the number from a spreadsheet to get the associated parts list. I then need to scan several of the assembly parts barcodes and check them off the list (in any order).
Currently I have this mostly working, but I have got stuck
(3,591 Views)
Sorry, not sure what happened to the rest of the post.
This is mostly working, but when the scanned input string contains text, I cannot get this text to be cleared when the state ("Get top level part number") is next entered. I have a feeling it is to do with the timings of the loops, but I cannot see why my method as shown is not working.
Any help would be much appreciated.
Ray
(3,577 Views)
What's exactly the problem? I don't see any error in your code and in fact the Scanned input control is properly cleared in my quick test.
Paolo
(3,551 Views)
Run the program in Highlight execution and Retain Values active. It should work but there might be something we're missing.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,539 Views)
Accepted by Radiator
Thanks for the responses. I now realise that the problem was limited to when I clicked the return key - this entered the data, but the scanned input string did not clear. However, if I clicked the OK button, this did clear the box. I then set the OK button Key Navigation Toggle "Set focus on toggle" check box and this has fixed the issue.
I have now turned this into a sub VI and it is all working OK.
Thanks for the advice,
Ray
(3,518 Views)
