Capture Global Keyboard Events
HI,
I'm looking to use Labview to capture a keyboard event directed to another application to trigger an output of a DAQ device.  This requires the other application to have focus and the labview app to be in background.
I think that using the 'SetWindowsHookEx' function from user32.dll might work?  Has anyone used this function in LV before?  Or is there another way to capture global keyboard events?  Thanks.
-Joe
(3,861 Views)
It's not easy to use the hook function.
Alternatively, you can use the Input Device Control VIs (on the function palette, Connectivity => Input Device Control palette).
George Zou
(3,848 Views)
You may also find this community example useful: https://decibel.ni.com/content/docs/DOC-13648
Brice Sorrells
Systems Engineer
www.ni.com/support
(3,819 Views)
Thanks for the ideas.  I will probably go with the Device Control VIs.  I don't think I've ever used them before; it appears that you have to poll the output (as opposed to using events)?  Thanks.
-Joe
(3,792 Views)
That's right.   You have to poll.  But it's a lot easier to code, and DEBUG!
George Zou
(3,789 Views)
