Situation: -
I am continuously acquiring data on 4 channels of the DAQ card using conditional triggering. Each loop captures 2000 samples, which are stored in 2-D waveform arrays containing each scan of each channel. The data is continually updated on a waveform graph for the user to monitor. After a period of "test time" or when you press a button, the loop will end and the last loop of waveform data gets passed to the analysis VI where all the calcs are performed (I only perform calcs/analysis on static data once test time has completed).
Problem: -
I now want to average the last 5-10 points prior to the while loop ending (as the injection needle will jump around slightly shot to shot). I can enable indexing on the while loop and then select the points I require afterwards (i.e. the last 5-10 or whatever), but this takes up a hell of alot of memory and the processor starts caching to disk too often. Can you imagine just how many points are stored in memory (2000 samples/channel, 4 channels per scan, sampling at 80KHz, for 10mins).
There is no need to store all these points. Each time the loop iterates, the buffer is cleared so the program runs quickly and smoothly. All I need to do is store the last 5-10 waveform array's and pass these on to the next VI, not the whole XXXXXX amount of arrays/point.
I may try and use a sequence, so that the first sequence uses disable indexing and ends after the "Test time" has elapsed. This then continues into the next sequence and proceeds to capture a further 5-10 shots with indexing enabled, before passing to analysis VI. This still doesn't really capture the last 5-10 iterations, it captures the next 5-10 iterations, but it would do.
Ideally, I want the while loop to execute with indexing disabled, and at a certain point in time (comparing the "Test Time" with the "sample rate"), the while loop changes to 'indexing enabled' which will build up an array of waveform data until the loop ends (about 5-10 iterations later).
Any Ideas. If you've got time on your hands..........
