Capture of 4 analog chanels, using one of them as a trigger
Thanks again for getting back to me.
That is really dissapointing news.. not sure what I'm going to do now.
You say that the start trigger would be do-able..? Do you think it would be simple to implement what I said, but in a simpler way to that the channels are just captured for a specified number of samples, after receiving the trigger edge?
Many thanks,
Mike
Message 11 of 15
(826 Views)
Mike,
Take a look at the DAQmx Trigger function.  I use the Start Analog Edge option in a system very similar to yours.  I do not know a way to simultaniously read and monitor the trigger for a "stop" signal.
What you could do is set your number of samples high enough that you have a resonable certanty of capturing all the required data, scan the trigger channel data for the third downward edge, then truncate all the signals at that point, and output to file / graph.  I recomend you change the DAQmx Read to output a 1D waveform.  Labview has a wide variety of tools for analyzing waveforms and they can also be easily truncated and written to file.
I might be able to rig up a sample if you need it.
=jason
Message 12 of 15
(805 Views)
Hi there,
thanks very much for the reply.
I had decided that what you suggested was probably the best (simplest option): i.e. to set up a digital trigger that then runs the signal capture of 3 or 4 analog input channels. I've been messing around with this all afternoon here.. I went through some examples and tried to modify them, but haven't got it to work yet. This may be because I've screwed up trying to (physically) wire in a digital channel to connect my pulse generator to. I'll attatch an example, perhaps you could suggest what's wrong with it..??
Many thanks,
mike
Message 13 of 15
(802 Views)
oops, I meant to say that the capturing of the analog channels will last for a pre-specified number of samples, that should allow all the data (probably up to 10 seconds worth) to be sampled... This is instead of the crazy start/stop thing I was going on about which I think is probably a bad idea for my sanity..
Message 14 of 15
(800 Views)
Well,
in case anyone finds this useful, I have now got the system working correctly (touch wood). In fact the VI i posted does the job nicely with our setup. The key was wiring in the trigger input to the correct terminals on the interface box.
Many thanks,
mike
Message 15 of 15
(783 Views)
