Capture to file the information shown in the project explorer "Files" tab?
Using the LabVIEW project explorer, if I go to the "Files" tab and select "Expand All" is there a way to capture the information shown other than a bunch of screen shots?  I'd like to get a listing of all the files used by the project along with the locations where they are stored.
Message 1 of 18
(3,952 Views)
Or you could just open the *lvproj file with any text editor or web browserSmiley Very Happy
Message 2 of 18
(3,945 Views)
At least in LV2013, under Project/File Information, you can export all the filepaths as a text file.
-AK2DM
Message 3 of 18
(3,944 Views)
Project Explorer Menu
Click on
Project \ File Information
Then you can export file paths
Omar
Message 4 of 18
(3,940 Views)
Jeff had the best solution though I had to tweak his code a bit to actually get a list of all the files.
I could get something like this to work for me. Thank you.
As for the other two suggestions to use the export-filepaths option, that does not work for me. It only exports the top-level file/VI names along with the project name (in the case of the project of interest, only four files are listed, when I'm expecting to instead see close to 500).
Message 5 of 18
(3,926 Views)
And opening that lvproj in ie?
Message 6 of 18
(3,911 Views)
           looks really ugly!
Nothing but line after line of run-on ASCII text and while there are file paths buried in there, there is at least as much other stuff that are not paths.
Message 7 of 18
(3,906 Views)
It is xml
Message 8 of 18
(3,901 Views)
I had tried a copy of the file with both .htm and .html extensions and it was quite ugly when opened. A  .txt file extension looked a bit better but there were still large areas of run-on text.  Changing the extension to .xml brings more order to it but that only puts lipstick on the pig.  It's still ugly.
I really do like the first answer. I've already got a working VI that presents a list of all open projects and when one is selected it goes through an generates an array of all files used. Duplicates are removed from the array and it's all ordered/sorted by path. I can then browse through the array list or cause it to be written to a text file.
Message 9 of 18
(3,888 Views)
Open with from windows explorer. Don't change the extention
Message 10 of 18
(3,882 Views)
