Capture to file the information shown in the project explorer "Files" tab?
@JÞB wrote:
Open with from windows explorer. Don't change the extention
That, on my system, causes LabVIEW to open it and I'm once again looking at it from the perspective of the LV project explorer which is where we started in the first place.
Message 11 of 18
(897 Views)
Don't double click on it.
http://support.microsoft.com/kb/141275
Message 12 of 18
(889 Views)
Yeah,  Uhmmm.. Dennis is absoltetly right.  You did right click not left click the file in the Windows explorer correct?  all those options
Message 13 of 18
(879 Views)
I appologize for all the things I have said about you to myself since reading that.....
Do you REALLY have that poor of an OS? or were you really that badly trained?
Dennis-  This one is all yours!  you have a better tolerance for obsolecence than I can fake today!
Message 14 of 18
(872 Views)
For the life of me I cannot understand why it is so important to you that I accept this other answer of yours, especially after I have told you that I do like and can use your first answer and the second answer does not work here for me as it apparently does work for for you. I did, early on, try the right-click/open-with Internet Explorer and got the same reaction out of this Windows 7 system; IT OPENS THE PROJECT FILE IN LABVIEW!!!  See if the attached flash video opens/runs for you and you too can see what I see here. Perhaps this behavior here is caused by the way DOE has mandated that the OS be locked down but that's the cost of security.
Message 15 of 18
(849 Views)
Sorry I let my frustration show.
Its a fairly simple procedure but difficult to get accross from a smartphoneSmiley Frustrated
Message 16 of 18
(842 Views)
Dupe post
Message 17 of 18
(842 Views)
FWIW, attached is the LabVIEW 2013 VI that I built to produce a list of all files used by a project. It will produce this list for any project which it finds to be loaded into memory and then selected for listing at the time the VI is run.  The list can be written to an output text file and that output can also be limited to just the folders in use, which may help in determining which toolkits and libraries are used by a given project.  Testing here has been limited to two fairly large projects, but it seemed to work properly for those two.
Message 18 of 18
(833 Views)
