Capturing image or video by BT cam
we aredoing a project in class. We want to take images and process its with labview. The problem is that a Bluetooth cam and we don´t know how to pair with labview. The cam is installed in Windows (Xp) and has the port COM10.
Can anybody help us?
Thank you
(3,073 Views)
Go through here
start wiring and post if you stuck up anywhere
Mathan
(3,065 Views)
Ok, I didn´t ask the correct question. I mean, Is there any kind of drivers or vi that allow me to use IMAQ´s vis to work the images? I can connect with the cam, but I don´t know how to see the images. Something similar to "usb drivers forIMAQ" but for a BT cam.
(3,059 Views)
hi,
Can you post your Vi? or give some more details about what you want? what do you want to do with images using labview ?
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,057 Views)
I don´t have any VI, I don´t know how to do. I want to watch what the bluetooth cam is acquiering with labview. I can communicate with the cam by COM10 and it goes well with Labview, and I have the commands to communicate with the cam in that way. But I don´t know how to convert the answers in a visible image.
(3,016 Views)
