Capturing only one sample after analog trigger on a PXI4461 in Labview SignalExpress
Hi
I capture two waveforms (external excitations) with my PXI446, one on each AI. I use one of them as an analog trigger (rising edge @ some voltage), lets say AI0. I need the value of AI1 at the time (or fixed # of dt's afterwards) when the trigger occurs. I need just that one sample.
(Practically I use the 4461 as sample & hold circuit that has AI1 as an input signal and AI0 as the "sample" signal.)
Currently, I use a "subset and resample" step with a very small dt and it seems that it works but I dont like it.
The procedure above is within a conditional loop that collects 100 of these samples (acquire signal triggers 100 times) and produces a statistic of this ensemble (using the Statistics step).
Is there a better way to do this?
Aleksandar Andreski
(2,927 Views)
You should post questions about SignalExpress in the SignalExpress Board.
(2,909 Views)
Thanks Dennis.
Do I need to repost the question or can the thread be transferred automatically?
(2,898 Views)
Accepted by topic author alek_a
Question reposted at the Signal Express forum.
I will tag this thread as solved.
(2,877 Views)
