monitor runnig vis
hi,
        i creating a new software product using labview, in this user can set a visual screen them self and can able to select the channel for each controls and displays, like a indicator, graph...
i created a Vi template for indiactor.vit, Graph.vit..... using menu user can pop up the indicator and graph, so each vi template will create a new vi and run on the main.vi, all vi templates are floating vi.  so, user can able to access main vi also.
i just wanted to know how to read the running vi name. because, i want to save the vi name  and also i want to close the all vi when the main vi exit.,
Balaji DP
(2,550 Views)
Have a look at the snippet below.  It should serve as a starting point.
The property node on the left provides a list of all the VI's in memory.  Within the For Loop, you get the reference for each VI and you can usea property node toobtain the info that you need.
Message Edited by Ray.R on 05-18-2010 09:03 AM
(2,531 Views)
