Carriage Return in Tip strip
Is there a way to introduce a carriage return in a tip strip, to allow tip to be more vertical than horizontal?
Message 1 of 13
(4,762 Views)
Hello!
Use the property node "Tip Strip". There you can give a string constant containig carriage returs.
See picture.
Have a nice day
Ken
Message 2 of 13
(4,756 Views)
If you modify the tip strip via a property node you're able to do this.
EDIT: Oops, beat to the chase!
Message Edited by Will.D on 11-15-2006 10:01 AM
Message 3 of 13
(4,754 Views)
Shift Return works for me on 8.2.
Message 4 of 13
(4,727 Views)
I know this is an old thread, but I'll ask anyway.  Is this do-able with labview 5.1?  I notice that some fields are not available when adding the property node...are tip strips available with this older version of labview?
Message 5 of 13
(4,309 Views)
I don't have a copy of LabVIEW 5.1 handy, but I'd suggest looking through the property node thoroughly.
Product Support Engineer
Message 6 of 13
(4,272 Views)
[Wize-Arse Comment]
James,
I will personally give you 10 Kudos is you can tell me how to find a property node* in LV 5.1.
Ben
Message 7 of 13
(4,239 Views)
* ... and attribute nodes don't count. Smiley Happy
Ben
Message 8 of 13
(4,236 Views)
Oh Burn he got you bad rookie!! 🙂
Sam S
Message 9 of 13
(4,206 Views)
i know...I'm new here! anyways, i just might give him Kudos for that Smiley Very Happy sorry bear with me guys.
Message 10 of 13
(4,198 Views)
