Creating a PDF in Labview
I am trying to open up this zip file, and I am able to get to open all the way, to the point of inserting a "test" .txt file to turn into a PDF, but when it asks for the PDF Path, I am unsure of what to put in. Seems like everything I try I get the error that is in the attached JPG file. Error 2147221164. Is there a different way to enter in the PDF save path? What am I missing?
Mike
(3,519 Views)
forgot to post the jpg Smiley Tongue
(3,512 Views)
suppose I should have put up the PDF creator zip file I have been trying to figure out.
(3,492 Views)
That error code indicates the ActiveX component that you're trying to use is not registered. Have you registered it? Sometimes ActiveX components are installed but not registered. You can manually register the ActiveX component by using regsvr32.exe at a command line, and giving it the full path to the component (.ocx or .dll file).
(3,423 Views)
