Case Structures function help
Hello
So i am currently working on code that will deal with more than one case structure functions (in total roughly four). Within the case structures, I will be dealing with RTDS and 2 pump meters. I need help with LabVIEW to interpret what I am trying to say and I am not sure of where to begin
1. If the user wishes RTD to measure temperature between 5-20 degrees, allow pump 1 only to pump. and allow max pump rate of pump meter to be 6litres per minute.
2.  If the user wishes RTD to measure temperature between 36-46 degrees, allow pump 2 only to pump. and allow max pump rate of pump meter to be 6 litres per minute.
3. If the user wishes RTD to measure temperature between 20-36 degrees, allow both pump 1 and pump 2  to pump. and allow max pump rate of both pump meters pump meter to be 3  litres per minute respectively.
4. If  RTD  temperature is met, shut down both pump 1 and 2 respectively.
Cheers,
(2,958 Views)
HI suppaman,
all you need is just one case structure with 4 3 cases. And an additional check for "temperature is met"…
(Depending on the kind of pumps (or their controllers) I would use a PID control loop to set the temperature. You can set the output range of the PID according to your requirements.)
There is a Training section in the header of the LabVIEW board - check the courses offered there!
You also could attach your current VI to get more help on it.
Good advice: NEVER compare floating point values for equality!
(2,935 Views)
Hello
Thank you for your reply. I was wondering if I can send a private message regarding my code with a bit more explanation I can give.
Cheers,
(2,907 Views)
@suppaman wrote:
Hello
Cheers,
Paraphrasing;
"A man does light a lamp and cover it with a basket."
When we share our insight in a public forum, our knowledge helps more than just one person.
Just my 2 cents,
Ben
(2,905 Views)
