VLC opens a window when running a LabVIEW EXE
Dear all,
I am trying to play a video in LabVIEW using VLC following these examples:
https://forums.ni.com/t5/Example-Program-Drafts/VLC-scripting-in-LabVIEW/ta-p/3515450
Everything works perfectly fine when I run my application on LabVIEW. When I compile an EXE and run my application, the video is not displayed on my front panel anymore but in an external VLC window.
Everything works fine when I run an EXE of the compiled examples.
I didn't do any change to the example code in my application and I cannot see any difference.
Unfortunately, I cannot share the whole code but I can still can some parts if needed (just ask).
Does anyone have any idea about what can cause that inconsistent behavior?
Thank you in advance.
CLAMaxime -- Kudos are a great way to say thank you
(2,946 Views)
Accepted by topic author ML927
Solution : it seems that resetting the default values for all front panel controls was the cause. I am not quite sure why but removing the invoke node solved the problem.
(2,899 Views)
