Case structure Hex not working
Hi all,
I have a problem with a case structure using hex display.
If I use a case structure (true/false) in combination with an 'equal?' function, the boolean will light up (top example in my labVIEW file).
However, if I connect the same byte directly to a hex case structure it is not detected, and my boolean2 will not light up.
I think that it is something really simple, but I cannot find out what is going wrong.
Hopefully someone can help me!
(2,591 Views)
Accepted by Bryan_1995
You are typecasting to an I32,  so that winds up being x0500 0000 or decimal 83886080.    Much larger than 5.
You need to typecast to U8
You can get rid of the upper case structure and just wire the comparison directly to the boolean indicator!
(2,578 Views)
Thank you! This is the solution for the problem.
Thanks for the suggestion, I know that this is better. I forgot to delete it when I was trying to simplify the script for making my question more clear.
(2,568 Views)
That's understandable.  It definitely helps when you are able to clean up the diagram of items that don't directly affect the problem you are demonstrating.
(2,563 Views)
