Case structure, case selector numerical control.
Hello all,
 I want to know how can i change numerical values inside case selector in case structure using numerical control. Example: I want to make a LabView program that alert me if the temperature is below the minimum or above the maximum temperature using case structure. Also i want numerical control to change Max and Min temperatures inside the case selector.
Thanks is advance.
(4,030 Views)
Sounds like you might want to implement a state machine. The enumerated type is saved as a control, which makes it easier if you want to edit it with additional states later.
(4,024 Views)
Accepted by joe1997
You can only edit the values for the cases of a case structure during edit mode (ie from within the block diagram). You'll have to use "bigger than", "less than", and/or "in Range" to check for these three cases with variable limits.
Regards, Jens
Kudos are welcome...
(4,015 Views)
Thanks this worked 🙂
(3,969 Views)
