Case structure, case selector numerical control.
Hello all,
 I want to know how can i change numerical values inside case selector in case structure using numerical control. Example: I want to make a LabView program that alert me if the temperature is below the minimum or above the maximum temperature using case structure. Also i want numerical control to change Max and Min temperatures inside the case selector.
Thanks is advance.
(3,972 Views)
Sounds like you might want to implement a state machine. The enumerated type is saved as a control, which makes it easier if you want to edit it with additional states later.
(3,966 Views)
Accepted by topic author joe1997
You can only edit the values for the cases of a case structure during edit mode (ie from within the block diagram). You'll have to use "bigger than", "less than", and/or "in Range" to check for these three cases with variable limits.
Regards, Jens
Kudos are welcome...
(3,957 Views)
Thanks this worked 🙂
(3,911 Views)
