Case structure default
Thats super helpful! Thank you ! one doubt though. When I first pass 3 and want 3 again I connect first shift register on the left to the one on the right. Say after setting first two as 3 and 4, next I need to save both till my temperature sets. How do I feed two elements to one register?
Message 11 of 12
(1,154 Views)
Accepted by Vishwaramesh
Break this example apart and understand how it works.  Once you do that, you can apply similar logic to your application.
Message 12 of 12
(1,150 Views)
