Case structure isn't updated after modification of "enum" type
After modification of a "enum" type, the case structure wasn't updated - it still contain 2 states, whereas after modificatiion it must contain 4 cases.
Is it normal behavior ?
Pavel
Message 1 of 16
(5,351 Views)
Did you actually tell the case structure to add the new cases after changing the enum? Did you look at the right click menu?
Message 2 of 16
(5,331 Views)
Well, I considered that once "enum"-type variable that is connected to case structure changed, the list of cases in case structure is updated automatically.
But it seems that case structure doesn't work in such manner.
So, after "enum" type modification, one must add all new cases into case structure manually. Correct ?
Message 3 of 16
(5,316 Views)
Yes, or automatically when you select to create all.
Message 4 of 16
(5,300 Views)
"Create All" ... where it's accessed ?
Message 5 of 16
(5,288 Views)
Right click on the case structure and select 'add case for every value'.
(blog)
Message 6 of 16
(5,273 Views)
In my 2015 version there is no such option, only "Add Case After", "Add Case Before".
Message 7 of 16
(5,253 Views)
Norbert
Expert: Geometry
Message 8 of 16
(5,245 Views)
In my version it looks like this:
Message 9 of 16
(5,228 Views)
What do you actually have connected to the case selector? Your image does not show this. It must not be an enum.
Message 10 of 16
(5,216 Views)
