talk to Keithley 6485 by Labview
I write a labview code to talk to my ke6485 by VISA. but It doesn't work. intiallize it is Ok, but it can't read data from ke6485. I'm a newer for Labivew, I don't know what's wrong with it. looking forward to any suggestions. Thanks very much!
And I have tried to download a driver (6485-852C02.exe) on the website, but it seems  didn't work on my labview. I use Labview 2013, and the driver seems work for Labview8.
(4,035 Views)
Where did you come up with that command string you are sending the instrument?  That looks nothing like a SCPI command like what the instrument is setup to take.  Go through section 7 of the manual for the proper commands to get the instrument to do what you want.
GCentral
(3,979 Views)
Thanks! I've solved my problem. Now, I give my code to here, hope it will help someothers who confused the same question.
(3,922 Views)
