Chage domain for MSSCCI source control
We rencenly change domain names here at work. Now I can't get source control to configure. I have Visual Studio connecting correctly to TFS but now the MSSCCI configuration throws an error when I try to connect. The error is "Error -2908 occurred at prefPage_Source Control.vi"  Possible reasons(s): LabVIEW: An error occurred while accessing source control. Check for network or contention poblems. [Continue]
When I 1st tried to configure it wasn't listed in the provider drop down box. So I uninstalled and installed the MSSCCI client again. Then I showed in the drop down box but now give the error when I try to confivure it.
Norm
(3,873 Views)
More info:
LabVIEW 2013 SP1
Windows 7 Enterprise SP1
(3,841 Views)
Maybe there is some registry key being set. You could try to remove any entries on the LabVIEW INI file SCC on the name.
(3,827 Views)
