Challege - Unbreak this VI
While editing some VIs, my fingers slipped and I entered a back door into a place where I wasn't supposed to be.
So of course I had to poke around.  And I discovered a way to break a global VI.
The challenge is:
  1. Figure out why the VI is broken.
  2. Fix the VI.
Message 1 of 13
(3,555 Views)
1. ??? Gloabal memory usage seems a bit off. ???
2. Does the attached work?
-AK2DM
Message 2 of 13
(3,509 Views)
1. You're on the right track,  The broken VI has something extra.
2. You didn't fix the broken on, you just built a new one.
From now on, use the VI attached to this post rather than the original (It will be easier to tell if a 'repaired' VI is from the one provided).
Message 3 of 13
(3,495 Views)
Somehow you managed to put a label and a Not primitive on the BD.
-AK2DM
Message 4 of 13
(3,482 Views)
Well, I was going to say that the unwired not primitive on the BD which shouldn't exist is probably not helping things, but it looks like you beat me to it...
P.S. And yes, I did leave that comment there.
___________________
Try to take over the world!
Message 5 of 13
(3,476 Views)
It was here, not there, within the comment 🙂
I can't figure out how to fix it, I have to go measure some micron-level stuff for now.
-AK2DM
Message 6 of 13
(3,470 Views)
Accepted by paul_a_cardinale
By deleting the unwired not, like so.
___________________
Message 7 of 13
(3,464 Views)
My path to the BD was:
1. Drop the global onto a Static VI reference.
2. Hold down Ctrl while double-clicking that reference.
Is that how you got in?
Message 8 of 13
(3,453 Views)
No. While someone once showed me that method, which he stumbled upon accidentally, I didn't remember it. I used the heap peek window.
___________________
Message 9 of 13
(3,447 Views)
I created a beta bug for this behavior. I'm not sure if NI will actually do something about it, because it's a corner case, but now it's up to them.
___________________
Message 10 of 13
(3,407 Views)
