Change File Path to excel file
So I have changed this previously, but I have gone back to change it and I cant remember and Labview is far form intuitive.
Attached image - I want to change the file path
(2,990 Views)
You just need to update the control value?  You can use the browse button that is part of the control.  I like to drag the file from Windows Explorer to the control and the control will get the file's path.
(2,948 Views)
