Data acquisition with labview on odroid c2 board
Hello, this is the first time, I do not know if it's okay. Basically what I want to do is to install the labview on a board (ODROID-C2) which by what I see exceeds the raspberry pi 3 and from what I saw, have what it takes and more to be able to install the labview program By the way I have Version 15) this board (the odroid) has an ADC converter that RP3 does not have What I want to do is take the corresponding port (adc) of the data plate and then, after processing them, send them to Other ports on the board. I want to know if this can be done. How do I tell the program (labview) that x port is an adc and that it has to take the data that comes from that port and then sends them to me by another port? Can it be done Or am I wrong? Micro is an ARM by the way. Thank you very much
(3,384 Views)
You might want to go to the LabVIEW makerhub forum for these kind of questions. (e.g. Linx)
(3,356 Views)
ok ok thx
(3,300 Views)
