Change Font Size of Label
I want to change the font size here. If you see the font size of the label of the button which I marked 1 is different from the one I marked 2. I need to make both the label font size same. How can I do that. Please help me. Thank You.
(4,415 Views)
Select the text you want to change. Use Ctrl - (minus) to shrink, Ctrl + to increase size.
Paolo
(4,408 Views)
Accepted by govindsankar
Hi govindsankar,
select the text, then use that font selection tool in the menu bar.
Or press anything from Ctrl-0 to Ctrl-3…
(4,404 Views)
Thank You. Pressing Ctrl + 0 worked.
(4,375 Views)
macOS:
As of LabVIEW 2023 (Q3)
Just as the ability to zoom in (or out) now defies "CMD-Shift +" (or "CMD-Shift -"),
the shortcut to increase (or decrease) Font Size has been re-defined to "CMD-Shift >" (or "CMD-Shift <").
(2,196 Views)
