Change Font Size of Label
I want to change the font size here. If you see the font size of the label of the button which I marked 1 is different from the one I marked 2. I need to make both the label font size same. How can I do that. Please help me. Thank You.
(4,397 Views)
Select the text you want to change. Use Ctrl - (minus) to shrink, Ctrl + to increase size.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(4,390 Views)
Accepted by topic author govindsankar
Hi govindsankar,
select the text, then use that font selection tool in the menu bar.
Or press anything from Ctrl-0 to Ctrl-3…
(4,386 Views)
Thank You. Pressing Ctrl + 0 worked.
(4,357 Views)
macOS:
As of LabVIEW 2023 (Q3)
Just as the ability to zoom in (or out) now defies "CMD-Shift +" (or "CMD-Shift -"),
the shortcut to increase (or decrease) Font Size has been re-defined to "CMD-Shift >" (or "CMD-Shift <").
(2,178 Views)
