Change Run-Time Menu in Packed Library
Is it possible to change the run-time menu of a VI in a packed library? I have a plug-in based application I created using Actor Framework, and ran into an issue after building one of my actors into a packed library. I had been setting the run-time menu of the Actor Core based on which child actor was launched but it will no longer change from the default menu. So far I have not been able to find any documentation indicating whether this property should be available in a PPL or not.
I created a test application (see attached) to verify that it is a packed library issue, not specific to Actor Framework. I am unable to set the run-time menu for a VI in a packed library whether it is an actor or not.
(3,677 Views)
Hello Cy_Rybicki
If you attempt a simple VI that calls to a run time menu do you get the same behavior? I'm referring to one like below:
Programmatically change run time menu.pngProgrammatically change run time menu.png
(3,635 Views)
Calling the VI using your method produced the same results. When calling the unpacked version, the VI will properly display the custom run-time menu. When calling the packed version the default menu is displayed even though the VI's run-time menu property nodes reads back the correct menu path.
(3,629 Views)
Hello Cy,
To clarify, custom run-time menu's can be used in PPL's. However, when the specific RT Menu Path property node is executed in a PPL, the path is populated but the default run-time menu is used.
This behavior has been documented in CAR #743026.
Ryan B.
Technical Support Engineer
(3,567 Views)
