loop to array in a loop for multiple arrays
Goal:
Input data (x,y) and plot bar graph.Then take this data and make a Gaussian array for each X position with intensity Y. Sum Gaussians to make a single array of the sum of Gaussians.
Thoughts. Make X data array. Put that through a loop to get a Gaussian. Need help to summing Gaussians.
Thanks for any help!,
JK
(3,445 Views)
Accepted by topic author JohnKellyPhD
Is this what you are looking for?
Note I did not go through your VI, it can probably be simplified, mostly likely by someone whose initials are CA. 😉
(3,418 Views)
Wow. That was awesome! Out of curiosity, was this is simple fix and a new user error?
-JK
(3,391 Views)
Relatively simple; mostly indexing array errors.
mcduff
(3,387 Views)
