Change Style of Controls
Is it possible to change a modern style "XNET Signal" control to a classic style one?
Thanks.
Ian
(2,830 Views)
Where is this control in the palettes? Is this from a toolkit?
(2,785 Views)
It is listed in a palette, but it may be from the CAN/XNET toolkit.
I can find it from Modern Controls palette->I/O->XNET->Database->Signal.
This control is not in the Classic Controls palette.
Thanks.
Ian
(2,778 Views)
What's the data type?
(2,774 Views)
It is a "XNET Signal" control.
(2,767 Views)
CA, It's an XNET Property (container).  It might be customizable the hard way with the control editor but the TK only installs "Modern"
See the help file on Custom Controls
(2,764 Views)
Here is one XNet Interface control that is a system which I like.
https://forums.ni.com/t5/LabVIEW/How-to-modify-X-Net-Interface-Control-in-System-shape/m-p/3359578#M...
But I haven't found other XNet controls that are in other style.  Most of the time I just use a combo box, or some drop down since the XNet controls just have a string data type anyway.
(2,725 Views)
