Change Value (active row) of multicolumn listbox using mouse
Hi Is the a way to change Value (active row) of multicolumn listbox using mouse?
Message 1 of 14
(6,195 Views)
If it is a control yes, if it is an indicator no!
Rolf Kalbermatter  My Blog
Message 2 of 14
(6,187 Views)
Ha ha. That's a short answer Smiley Very Happy. I dont expect you want to reveal how?
Message 3 of 14
(6,134 Views)
Can you give more detail on what you have and what you're trying to do?  As Rolf said, if your listbox is a control, mouse interaction is a natural function, but if it's an indicator, it's not.  And, of course, if it's a control but you have it disabled, you'd need to enable it before you can change the active row with the mouse.  Can you post any code as an example?
______________________________________________________________________
The avatar is for the best weapon in any game ever. But nobody goes there anymore.
CLAD, LV2013, LV2015
Message 4 of 14
(6,127 Views)
Accepted by Michael.Koppelgaard
Here's one way to do it.
Message 5 of 14
(6,117 Views)
Wauuu that's brilliant
Spoiler
Smiley Very Happy Smiley Very Happy Smiley Very Happy
Message 6 of 14
(6,100 Views)
Hi
How do you get access to point to row coloumn property node ?
Message 7 of 14
(6,057 Views)
The answer is only slightly shorter than your question! Smiley Very Happy
If you had elaboated a little more about what your problem is, I might have expanded on my answer. As it was my first thougth was that  you simply were trying to operate the listbox control after you had made it into an indicator.
Sorry for my underdeveloped mind reader ability.
As to your last question about how to get access to the Point to Row property node I again struggle to understand what you are asking. You have the snipped posted so you have access to the actual VI. Obviously you have the method node (this one is not a property node!) already there and the actual method selected. So you simply place a method node on the diagram and wire it to the object refnum and voila!
Message 8 of 14
(6,052 Views)
What do I want to do??
Sorry for being so not corroborative
I have 2 instruments. I want to adjust the instruments after the value in the row header. I want to put the output from instrument 1 in col 1 and from instrument 2 in col 2.
I want to be able to jump from row to row using the mouse click function and use this value to set the instruments.
From dave_st’s answer, I understand that it’s also possible to use the mouse wheel to change the value of the multicolumn object. I didn’t know that.
I hope my explanation is understandable.
Message 9 of 14
(6,039 Views)
Here's an example I wrote up.  I'm not entirely clear on how you want to bring the data in to the listbox or what you want to do with it after, but that's okay--the important part is extracting it.  Hope this is the kind of solution you're looking for.
Message 10 of 14
(6,012 Views)
