Change Width/Height Left/Top of Ni Max in Labview programmatically.
Hi to all.
I would like to change Width/Height Left/Top of NI MAX (see picture) from my programm in Labview programmatically, so that user will be able to change that values without enter in NI MAX.
How can I do that? which block or property node can I use?
Thanks a lot.
Message 1 of 10
(4,652 Views)
Hi Alvaro,
why do you want your users to use MAX in parallel to your VI?
And why don't you set the ROI in your VI?
Message 2 of 10
(4,651 Views)
Hi GerdW:
I would like to change those values in my program, not in NI MAX.
Those values are not a ROI itself, those values are image size (Heigth/widht) and offset image (Left/Top)
Thanks again
Message 3 of 10
(4,642 Views)
Hi Alvaro,
So you need just 4 numeric controls!?
Message 4 of 10
(4,638 Views)
Exactly, but those numeric controls are input of which block, property node....????
Message 5 of 10
(4,635 Views)
Hi Alvaro,
What do you want to achieve with those values?
Where do you need them?
Which functionality should your VI provide?
Are you working with IMAQ/Vision?
As long as you don't provide information you will only get generic answers…
Message 6 of 10
(4,633 Views)
I would like to change image atributes (height and width) and camera offset (left and right) (see image first post) programatically with a control that user can change because sometime usar wants to see a bigger image displaced image.
I need controls that user can change in the front panel. These controls have to do the same things that the controls in NI max (height width left and right) (see first post image).
Yes, I am working with this toolbox in labview.
Coud you help me?
Thanks a lot.
Message 7 of 10
(4,525 Views)
Hi Alvaro,
unfortunately I cannot help you with IMAQ issues.
I guess there are functions or properties/methods you can use in IMAQ…
Message 8 of 10
(4,521 Views)
I did the next steps:
1. I use enumerate attributes to get name of width atributte:Sin título.png
2. I try to set attribute with the next code and return this error:Sin título2.png
It make sense because in enumerate attributes it says that width attribute is only readable.
However I can change this attibute in NI MAX (see first post image) because when I change this attribute in NI MAX and then I go to my labview program and read width attribute, the value has changed....
So why can't I change this value in labview program with imaqdx properties? How could I do this?
Thanks a lot.
Message 9 of 10
(4,513 Views)
There are two basic ways to "influence" hardware with LabVIEW.  One is to use MAX, an interactive (meaning "manually controlled by a Human through a User Interface") program that, in turn, "talks to" various NI Drivers that, in turn, interact with the hardware.  The other method is to write LabVIEW code that also interacts with the Drivers (that interact with the Hardware).
The first "MAX" method is designed to be interactive, and hence not "programmable".  The second "LabVIEW" method is completely programmable, although there are some "shortcuts" called Express VIs that do some of the simple programming for you.
So while it is easy to do what MAX does with LabVIEW (i.e. open a Camera, Snap an Image, display it on an Image Display, and drop a rectangular Region of Interest (ROI) on it, you need to write some LabVIEW code to do this!  Once you have done this, you can Query the ROI for its properties and even set them programmatically.
A word of caution -- acquiring and processing Image Data using LabVIEW is somewhat more complicated, less-well documented, and more difficult than other forms of data acquisition and processing in LabVIEW (such as VISA or DAQmx).  I would advise having a few months of LabVIEW experience (or access to an experienced LabVIEW developer) before venturing too far into these less-well-charted waters.
Message 10 of 10
(4,507 Views)
