GerdW,
If you open a reference, and then, in a loop, change the title, there is no
problem.
But if you open a reference and change the title in a loop, you get problems
when you don't close the reference. This does not happen when you don't use
the Open VI Reference.
The attached VI will hopefully clear things up...
Wiebe.
"GerdW" wrote in message
news:5065000000050000001FD90100-1079395200000@exchange.ni.com...
> Hello Wiebe,
> what do you mean with new and old reference? Does the reference of the
> vi change, when you change the FP.Title property?
> I have a vi, that runs as long as I'm sitting in front of my computer
> (say 10 hours a day). It sets the title every 90 seconds to signal
> running pr
ocesses in Windows taskbar. I close the reference on vi exit
> and never realize some memory leaks.
> Best regards,
> GerdW
[Attachment Change Title Leak.vi, see below]
