Change all project to edit mode
Hello.
Is there a way to switch an entire labview project to "edit mode"?
If there isn't, how can I make an individual vi always open in edit mode?
I have seen that they always open in run mode and even if I change it to edit mode and save it, the following times they always open in "run mode".
(1,972 Views)
What is "edit mode"? You mean a VI that isn't running and that you can edit? When you make a new VI the option "Run when opened" should be unchecked. Is this not the case in your situation?
(1,927 Views)
My wild guess is that when you say "edit mode", you don't really mean edit mode (which means not running); and that what you really mean is that you want the block diagram to open when you open the VI.
There's no built-in way to set that up.  You could create an XControl whose only function is to open the BD when the VI is loaded; however you would have to have an instance of it in every VI,
You could create a menu item that opens the BDs of all VIs in a project.
(1,914 Views)
No, I do not mean that. What I mean is that many vis open in "run mode" and I have to change this option to be able to modify the vi.
Even though I save it as edit mode, if I close it and reopen it, many of the vis open in run mode and I have to change it every time I open it. I was wondering if there is a way to make all the vis that the project has always open by default in edit mode.
(1,905 Views)
Accepted by topic author Alejandro1123
A VI usually opens in run mode when it is set to reentrant and you double-click one of its clones on a diagram. I also find this quite painful when navigating the code (especially in FPGA where everything is reentrant by default).
The easy solution is to press ctrl+M to switch to edit mode each time you open a VI.
The not-so-easy solution is to create a right-click plugin to open the original VI directly.
Here is an example plugin that adds a "Diagram" option when you right-click a SubVI in the code. It only opens the original diagram, so no clone and no front panel.
Put both subfolders in "<user>\Documents\LabVIEW Data\PopupMenus", then restart your LabVIEW. It should work for versions >= 2016.
Also, there is an exception for malleable VIs, it opens the instance instead of the original.
Raphaël.
(1,885 Views)
