Change color of outgoing frame in string
      The attachment contains an example vi to monitor frames. This is just an example. when i run the VI both outgoing and incoming frames color are the same, I  tried to make some work around but not working. I need to make the changes as attached pic. Please let me know how to do it?
Message 1 of 16
(4,532 Views)
Sorry I don't have LabVIEW 2015 installed on my machine just now. So cannot comment on your code. But you can use this: http://digital.ni.com/public.nsf/allkb/6BD344ACA4DEE20A8625692700737E16
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 2 of 16
(4,512 Views)
The string datatype contains no information about text color. It's just a bunch of data about alphanumeric characters. That means this code does nothing but change the color of the indicator:
aCa's solution is how you do it, but you'll have to mess around with your code a little bit because every time you update the value of the string, you will lose all of the colors previously present.
Cheers
Message 3 of 16
(4,507 Views)
HI,
        I have attached the VI for the ver 9.0. If any ideas let me know.
Message 4 of 16
(4,486 Views)
@jay0909 wrote:
HI,
You've been given the solution. Try out the text selection code above and see if you can implement it to your satisfaction.
Cheers
Message 5 of 16
(4,481 Views)
Nope it dosn't work. It changes only for the first row and rest is the same.
Message 6 of 16
(4,476 Views)
Sorry, wrong information
Message 7 of 16
(4,466 Views)
        Could please give some example programs that i can make it working as expected.
Message 8 of 16
(4,462 Views)
Try mixing the code above and your code to change the color of different rows. Experiment a little.
Like I said above, the colors get reset when you update the string, so you'll need to change the colors of multiple rows every time and it will take increasingly longer as your string gets longer.
Cheers
Message 9 of 16
(4,437 Views)
Is it just for display? I would use something like tree (for table, etc  you need to keep all messages separately)
Methods Add item to end, Active cell font color
Message 10 of 16
(4,429 Views)
