Change control values during SubVI call of a State Machine
Hi
I'm developing two JKI State Machines to control two Modbus Units.
I want to keep their respective control in a state machine, such that they can be used stand-alone.
Now I want to combine these State machines as Sub VI to do various automated control. How can I call a JKI State Machine as a Sub VI and during its call change some control values, like programmatically pressing a button to enter a new state?
(914 Views)
I'm not familiar with JKI SM specifically, so ma answer will be broad about communikation with a sub-vi.
There are several ways, but the main idea is to make this communication follow a "by reference" approach, instead of LabVIEW's usual "by value" approach.
You could pass a queue into the subvi. You could the feed the queue in the caller and consume it in the sub-vi. (Queue are for one consumer only though)
You could use user events in a similar fashion. This could work with multiple such sub-vis simultaneously.
You could obtain references to the buttons in your sub-vi and pass them to the caller (via FG e.g.) and "press" them with property nodes (works only if mechanical action is switch)
Hope these are some good starting points.
(908 Views)
