Data Acquisition With a Fiber Optic Reflective Memory Module (PCIE 5565PIORC)
I'm evaluating possible options for acquiring data with a Fiber Optic Reflective Memory (FORM) card (PCIE 5565PIORC) and I wanted to check in with the community to see if anyone has done something similar, or if anyone had any suggestions for hardware/software to get me started. I've searched online a bit and found that I will probably need a PXI chassis and the LabVIEW Real Time Module, but I am not sure which PXI chassis would be compatible with the FORM card and I'm hoping someone might be able to help point me in the right direction.
Joseph Kohl
(1,659 Views)
Hi Jkohl ,
Software - LabVIEW Realtime itself enough .
Hardware - PXI 8880 would be perfect for the acquisition speed and reliability.
May i know which tool you are acquiring from or sending data to LabVIEW ?
(1,581 Views)
