Change field in database
Is there a way to change (update) one field in a database?
So I have a 2D-array in the database and I know the index of the row and column of the field I want to change.
Another way is reading the 2D-array, changing the 2D-array deleting the 2D-array from the database and insert the new 2D-array in the database.
But I'm afraid this will make the program slow.
So I hope there is faster/easier way?
(3,716 Views)
Accepted by topic author gihlutax
You would use the SQL UPDATE command.
http://www.w3schools.com/sql/sql_update.asp
(3,698 Views)
OK I see, I now see the condition terminal on the update function of the connectivity toolkit, I did'nt see it 🙂
(3,683 Views)
