How do I make an event handler for a .NET assembly?
I've been given a .NET assembly, and to use it I need to pass it a reference to an "event handler function", which takes arguments:
(object sender, ProprietaryEventDataType eventArgs)
Will I need to program one of these? If so, can it be done in LabVIEW? Should I expect to know what eventArgs the assembly can produce?
Very new to .NET and event based programming in general, so if you need more info please ask.
(3,329 Views)
(3,288 Views)
