06-27-2011 04:22 PM
I couldn't find an answer for this but: Is there a way to chnage the font in the front panel by pressing a button?
As you can see, I am building a farily simple starwars-theme-application, what I want to to is to use that funky starwar font ( like the one os top of the siganl inputs), but when a button is press the font goes back to a readable font (ie; arial)
Solved! Go to Solution.
06-27-2011 04:25 PM
You can create a property node for each of the controls you want to change. Write the font name to the property Label.FontName.
