Change "User Data Folder" Webview2
Hello, I'm trying to change the path "User data Folder". Unfortunately, I get an error message. Search engine questions have only had limited success. What's going wrong, can anyone help with the problem? I'm attaching my program...
(1,142 Views)
Have you seen the webview2 control on vipm? It is very good and does let you modify paths .  You may find it a useful resource:
https://www.vipm.io/package/sklein_lib_webview2/
I use it and it is really good. Kudos to the creator!
(1,099 Views)
Accepted by Trebis21
Thanks for the answer. I tested sklein's VIPM. I also found my problem on Github:
UDF location for builds not working · Issue #7 · kleinsimon/LV-WebView2 · GitHub
That describes my core problem exactly. I implemented the solution there and am happy with it.
(1,066 Views)
