Change spacing between "LED's" in 2D boolean array indicator
Hi All
In my application I am tring to mimic a LED matrix sign using a 2D boolean array indicator. Its obvious enough how to chage the size of the LED's in the array indicator but I would also like to reduce  the spacing between LED's as I have very small leds with two much space between them!!
Could someone kindly send me an example or tell me waht steps to take using customize indicators function etc.
Also can this be changed programatically using property nodes, so for instance i can resize the spacing to mimic LED signs with different LED densities?
Many Thanks!
Tristan
(3,612 Views)
Hi Tristan
You could try customising the boolean in your array.  Right click on an element of your array, select Advanced->Customise....  You can then modify the appearance of the boolean to your requirements, using decorations for example to modify the spacing.
You will be prompted to update your array with the modified version once you have finished your edits.
Had a quick play, see attachments
Hope this helps
Steve
There are 10 types of people in the world that understand binary, those that do and those that don't.
(3,607 Views)
Thanks Steve, i have played around and managed to achieve what i want.
(3,597 Views)
