Change string indicator
Hi there,
I made a function to subtract two dates.
From this dates I only want to see the month and day (mm.dd).
The calculated value is inverted with the "Format Date / Time String" block.
I did put some more information in the picture that I added as attachment.
I hope my problem is clear.
Thanks!
Greetz
(3,518 Views)
I'm not sure I understand your problem correctly. You just want to hide the border of the string indicator?
The simplest solution is to use a "Simple String" from the "Classic" palette. Then just paint it transparent.
Hope this helps
(3,513 Views)
Use a Simple String from the Classic String & Path pallet, then color it transparent.
 Doh!  Like he said.
Message Edited by jcarmody on 03-25-2010 06:35 AM
Jim
(3,512 Views)
