Fatal Error. Object not found.
 I have built aninstaller package cotaining the following:
3x .exe
LabVIEW2009 Dev Enviroment
VISA Runtime Enviroment
NI-DAQmx
When I try running the installer (from the local hard disk) I get the following error, any ideas anyone?
Cheers inadvance, Alec
.\Distribution.cpp(320): IInstallerError 10002
class CPart object lookup by ProductCode failed to find object {9A832E3A-8676-41CC-A945-9C6827D00B4C}
(5,333 Views)
(5,318 Views)
Accepted by topic author alecjcook
I was building the installer straight onto a network drive. If you build the installer locally and then copy it to a network drive it works fine.
(5,309 Views)
Glad you have it solved and thanks for updating...:smileyhappy:
(5,305 Views)
