Change tabbing shortcut for controls
Is there a way to change the tabbing shortcut to the Enter key, instead of using the Tab key? And is it possible to set the tabbing order for controls?
Chris
(2,386 Views)
Accepted by CLH239
I would advise against it as using the Tab key for navigation has been standardized for a long time.  But you could use the Key Down? filter event in an event stucture to modify a keys behaviour.  Specifically if someone hits the enter key pass 9 to Char and ASCII to VKey.  You could also use this to disable the tab key.
(2,374 Views)
Thanks Don,
That was what I needed.
(2,362 Views)
