Change the transition order in the state diagram
I am running Labview 8.0.1 with the state diagram. In the previous version of Labview 7, I was able to change the order of transition state. In the current version, I do not see how to change the order of execution of the different transition state. If I have 3 transitions in a state, A, B, and Default that point to two states State-Default and State-A. Transition B points back to the same state. I want to check the requirements on Transition B before I go to the other transition test.
How do you change the transition execution order. I believe under Labview 7 all you do is change it in the state diagram. In the current version, there is no option on the change.
(2,853 Views)
could you post the concerned VI?? and also tell in which order/condition you want transition to occur
(2,835 Views)
It could be pilot error, but all of the suddent the reorder transition menu has reappeared on the state diagram.
(2,828 Views)
Thank you for the update Joseph!
I was scared for a second there.
Ben
(2,825 Views)
