Change value of Boolean toggle switch during runtime
Well done Gerd. You are a true LV champ mate. Wish u Many happy solutions and Kudos  🙂
Regards
Asad Tirmizi
Design Engineer
Institute of Avionics and Aeronautics
" Its never too late to be, what u want to be"
Using LabVIEW 8.2
Message 11 of 14
(2,285 Views)
I am using LabVIEW 8.6 and trying to do a similar thing (monitor a measured value then deactivate a user selected toggle if the measured value exceeds a specified limit) but I don't understand Martin's second image that shows the triggered true state. I don't recognize the boxed Switch that is connected to the boolean constant. What function/control does that element represent, in what menu is it located? Thanks in advance.
Message 12 of 14
(1,827 Views)
It is a local variable of the switch.
Right-click the switch and "create....local variable".
(Make sure the switch does not have a latch mechanical action)
Message 13 of 14
(1,821 Views)
Implemented successfully. Thank you and kudos.
Message 14 of 14
(1,788 Views)
