Changed timed structure priority range in LabVIEW 8.2?
I've upgraded to LabVIEW RT 8.2. I recieved an error on one of my my previously "OK" timed loops: "invalid parameter". It didn't specify which parameter. After changing several parameters (DT, Name, etc.) I hit upon the priortity setting. Apparantly the range is now 1-65000 (ish) instead of the previous range of 1-2,147,480,000. Is this planned? Could you update the help file?
(2,969 Views)
Hello!
   I was able to set the range as mentioned in the help file (2147480000) just fine for a timed loop in PXI and cRIO.  The error probably is due to another parameter. Can you please let us know of the target that you are testing the same.  Please post a snapshot of the VI with other parameters you have configured in the timed loop. This will help me in identifying the problem.
Thanks and looking forward to a response
Regards
Avi
(2,940 Views)
I'm out of time for the rest of the week. I'll post the info early next week.
(2,921 Views)
